Post by leehadjiosif on Nov 5, 2018 17:34:01 GMT
The reverse polarity panel light is on. This usually means that the hot and neutral wires are reversed so I reversed the hot and neutral wires on my dock power extension cord thinking it should solve the problem if the dock supply has reversed polarity. The RP light is still on. Anyone has any ideas? Lee
Post by Caxton on Nov 5, 2018 18:14:54 GMT
Post by Don Reaves on Nov 5, 2018 21:30:31 GMT
If you have any doubt about whether the panel is indicating incorrectly, or if you're having trouble deciding if it's just dim and flickering, you can buy a simple outlet tester like this one from Power Gear, at least in the US. I keep one on board since my panel doesn't have a polarity light. Based on the number of complaints about the Scheiber panels, maybe I'm lucky.
