Post by leehadjiosif on Oct 27, 2018 17:33:28 GMT
Post by ohana on Oct 27, 2018 21:09:01 GMT
I am not familiar with the skin fitting in your photos, but would agree that seems strange not to have a collar nut of some kind with a largish flange. It looks as if it may have leaked in the past, hence the black sealant which seems to have been applied over the joint. I have to be honest, I dont like the look of this and while a pain, would suggest you lift the boat to have this investigated
Post by alenka on Oct 28, 2018 14:39:38 GMT
Got to agree... This doesn't look right. The last thing you want is a large hole in your boat below the waterline. I have heard of some people having through hulls replaced while they are still in the water. There is an obvious technique if you can find someone who can do it this could save you the cost of the lift.
Post by vasko on Oct 28, 2018 15:54:39 GMT
Same here - haven’r seen before this type , but may be normal and expected...
btw: kind if strange to change only the taps to grp... usually you change everything to grp...
Post by hoppy on Oct 28, 2018 21:20:33 GMT
The seacock valves look like they are tru-design www.trudesign.nz/marineAs everyone has mentioned, the thruhull is very strange looking. My guess is that they skipped the nut and used the L bend pipe to secure the thruhull in place. Maybe the skin fitting was cut short to do this. Probably a very bad DIY job. I think you should look at replacing the skin fittings and thruhulls with Truedesign, sooner rather than later.
Post by MalcolmP on Oct 28, 2018 22:35:17 GMT
Agree with consensus, best to change the skin fitting as soon as you can. I would fit a Trudesign thru hull then fit the valve to that then the bend as required eg www.trudesign.nz/marine/products/3-tail-long-thread-90I hate seeing an elbow fitted to the thruhulls then the seacock following. To be effective the seacock should always be the first in sequence
Post by mikebz on Oct 29, 2018 10:27:13 GMT
The topic title had me worried until I read the post...
Post by MartyB on Oct 29, 2018 18:08:14 GMT
Depending on which continent you are on, Forespar for NA has the Marlon fittings like true design as noted by some.
Martin
Post by leehadjiosif on Oct 30, 2018 16:38:22 GMT
The topic title had me worried until I read the post... HaHa!!
