Post by bareproductions on Oct 8, 2018 14:19:05 GMT
Hello All,
Anyone have a 379 with factory installed autopilot? I'm looking at a 379 without autopilot and am trying to identify the easiest ram, head unit, etc. to install.
Boat currently has a Simrad NSS12 MFD.
Thanks! -Chuck
Post by svejk on Oct 9, 2018 21:06:44 GMT
My SO37 a dealer installed linear drive at some point. It was in the starboard aft cabin. Link to the pic => Starboard Aft Cabin
Post by bareproductions on Oct 10, 2018 3:05:58 GMT
Thanks for the pic and info! Is the hole where the drive connects to the quadrant? I assume that L-shaped cover was added during the pilot install?
Post by sitara on Oct 10, 2018 20:44:18 GMT
Hi Chuck, You will probably find that there are pre-drilled holes for mounting the linear drive for the autopilot. My 36i had them that matched up with the Raymarine drive that I fitted. Good luck. Rob
Post by svejk on Oct 11, 2018 21:05:00 GMT
Thanks for the pic and info! Is the hole where the drive connects to the quadrant? I assume that L-shaped cover was added during the pilot install? Yes - it appears there's a tab on the quadrant to connect the linear drive. I still have to figure out where to put the rudder feedback unit but there should be room. And the cover was likely created by the contractor- a nice touch!
Post by bareproductions on Oct 14, 2018 15:20:06 GMT
Does the auto pilot work without the rudder feedback sensor? Or does the sensor just add an additional level of precision?
Post by Don Reaves on Oct 14, 2018 18:48:00 GMT
I've had a number of autopilots and never had a rudder position sensor. They work fine, but probably would work better with one.
