Post by meng on Sept 8, 2018 18:37:00 GMT
Hi All, The above mentioned mast and boom is on a Jeanneau 54 DS. I have problem changing the in mast furling line which some of the Allen key bolts have seized. Anyone has any idea if the spars are manufactured by Z Spars or Spar Craft? Any instructions / manual available online for the replacement? (Still trying to figure out how to upload pics as there are no options to pull from Win Explorer) Any help is appreciated. Thank you.
Post by MalcolmP on Sept 9, 2018 13:07:28 GMT
Post by meng on Sept 19, 2018 13:49:04 GMT
Thank you for the reply.
I have already emailed Marechal and see if they have any instructions available. Cheers.
Echappe'
Jeanneau Model: 2005 Sun Odyssey 54 DS
Yacht Name: Echappe'
Home Port: Charlevoix, MI (currently in Oxford, MD)
Post by Echappe' on Nov 5, 2018 21:50:09 GMT
If you have the Z Spar system, there was a great article posted on this forum about pulling out the mast furler and servicing it. We just did it and replaced the ring bearing. It's pretty easy other than dealing with any seized fasteners. I ended breaking one of the allen bolts off and had to drill it out, tap the hole with a larger thread and install a larger allen bolt. That aside, the job went really smooth. If you are doing this with the mast rigged, remember to use a halyard to hold the furler tube up so it doesn't fall down when you pull the furler mechanism out. Here's the link to the article. www.jeanneau-owners.com/hintsandtips/furlinglinereplacement.html
Post by lukabellanora on Mar 9, 2022 11:08:24 GMT
I have a SO 54 DS with in mast furling from Marechal mast. I have some issues with furling the main and I also need to service the drum and check the tension of the inner swirling profile.
Does anyone have a Marechal furling mast service manual or any kind of brochure regarding this mast?
