Deleted
Deleted Member
Post by Deleted on Aug 8, 2018 10:46:36 GMT
How do you guys keep your freeboard clean, especially right above the waterline ? What product(s) do you use ??
BIG THANKS, V.
Post by iancymru on Aug 8, 2018 12:33:27 GMT
www.pbo.co.uk/gear/10-gelcoat-cleaners-tested-26286/12I use Grunt or Y10 both really good and little effort required, usually make decision on what the chandler got in at the time. You don't need a lot of either and a little goes a long way. Wear gloves and do antifouling afterwards as it can streak the antifouling.
Post by vasko on Aug 8, 2018 20:00:47 GMT
I use the blue slime and so far very happy
Deleted
Deleted Member
Post by Deleted on Aug 8, 2018 20:26:22 GMT
I use the blue slime and so far very happy Which one is that ?? THANKS, V.
Post by vasko on Aug 8, 2018 21:41:49 GMT
Post by sitara on Aug 8, 2018 22:10:33 GMT
I used Grunt. Very quick and easy. Just make sure all residue is well washed off before polishing as I ended up with some dark streaks. They did come off with more grunt.
