Post by greg on May 19, 2006 17:53:18 GMT
My wife & I own a Prestige 36. It's a 2004 model - this is relevant to these models, later Prestige 36's have had a bathing platform extension. Our model is great, but we've been plagued by black smoke staining of the transom after virtually any passage. Due to aerodynamics, the smoke from the exhausts curls up and back into the cockpit - I'm sure that other owners this. The smoke stains the gel-coat and is a pain to remove and keep clean. Anyway, Jeanneau released a nice pair of fibreglass exhaust extensions - they are contoured for a snug kit and turn the exhaust gasses 90 degrees down into the water. Ask your dealer for details. It would have been nice if Jeanneau had contacted owners - I found out by accident. I've noticed new Prestiges (42, 46 etc have had an exhaust re-design), so they definitedly got it wrong on the first 36's.
Post by greg on Jun 21, 2006 20:38:12 GMT
Just an update to the above post... Firstly, we have a 2001 Prestige 36, not 2004. Also, I've now fitted the extensions and they seem to be working really, really well. The whole transom and cockpit was staining and smokey black all over the gelcoat, and now there's just a film of salt after a passage. Fantastic. Call you dealer and order them!!!
alexv
Post by alexv on Jun 30, 2006 10:34:07 GMT
Thanks for the tip. We have a Prestige 32 and I am als experiencing the problem of the exhaust coming back into the cockpit.
Post by seasage on Sept 12, 2006 21:12:48 GMT
I have the 36 with the 370hp volvo's and not experienced this problem but I do note that the exhaust on this model is below water level and might make the difference
artsi
Post by artsi on Feb 4, 2016 8:36:15 GMT
My wife & I own a Prestige 36. It's a 2004 model - this is relevant to these models, later Prestige 36's have had a bathing platform extension. Our model is great, but we've been plagued by black smoke staining of the transom after virtually any passage. Due to aerodynamics, the smoke from the exhausts curls up and back into the cockpit - I'm sure that other owners this. The smoke stains the gel-coat and is a pain to remove and keep clean. Anyway, Jeanneau released a nice pair of fibreglass exhaust extensions - they are contoured for a snug kit and turn the exhaust gasses 90 degrees down into the water. Ask your dealer for details. It would have been nice if Jeanneau had contacted owners - I found out by accident. I've noticed new Prestiges (42, 46 etc have had an exhaust re-design), so they definitedly got it wrong on the first 36's. I have Prestige 36 2004 and would like to get exhaust extensions but I asked from importer in Finland and they said they are not available from Jeanneau. Do you know any place in Europe where I could get these?
Post by MalcolmP on Feb 4, 2016 10:03:58 GMT
I have Prestige 36 2004 and would like to get exhaust extensions but I asked from importer in Finland and they said they are not available from Jeanneau. Do you know any place in Europe where I could get these? Give Dan Yeates at BHG Marine in the UK a try: www.bhg-marine.co.uk/If you are on Facebook there is an active Powerboat group at: www.facebook.com/groups/jeanneau/
Post by napoleon on Feb 14, 2016 19:25:43 GMT
We also have a Prestige 36 from 2004 which was fitted with the extensions from new. I can vouch for the fact that they work well but an earlier post on this subject (see 2011 this section) indicated that they were no longer available. Jeanneau do not seem to keep any records on such details. There was a minor concern about these devices early in their use which referred to increased back pressure in the exhaust system under about 2000 rpm. This supposedly caused minor vibrations in the engines but I suspect this was not the case other than in one particular vessel and caused by some other factor. Our engines have always run very smoothly at any speed and never shown any symptoms or cause for concern. The only downside is that it is not possible to see any telltale water flow from the exhaust pipes. A trick I have learnt is that on first start-up after a few days of not being used I put an ear to both rubber pipes just before they enter the silencers when the water can be heard quite clearly as it passes through (or not!). Napoleon
artsi
Post by artsi on Mar 14, 2016 7:01:08 GMT
Hello!
Does anyone have any pictures of these exhaust extensions?
Post by napoleon on Mar 18, 2016 20:11:08 GMT
Hi artsi, Have been trying unsuccessfully to send photo of exhaust extensions but can't get the hang of the system. Will send by email if you can put an address in my message box. regards, Napoleon.
Post by stephen2 on Jun 20, 2018 15:26:50 GMT
Re: exhaust extensions / elbows, has anyone had any success in sourcing these as Jeanneau no longer supply. Any suggestions grateful received.
Post by blanck69 on Aug 12, 2018 15:55:38 GMT
Same Problem! Where can I purchase these Extentions??
Post by blanck69 on Aug 15, 2018 16:38:00 GMT
My wife & I own a Prestige 36. It's a 2004 model - this is relevant to these models, later Prestige 36's have had a bathing platform extension. Our model is great, but we've been plagued by black smoke staining of the transom after virtually any passage. Due to aerodynamics, the smoke from the exhausts curls up and back into the cockpit - I'm sure that other owners this. The smoke stains the gel-coat and is a pain to remove and keep clean. Anyway, Jeanneau released a nice pair of fibreglass exhaust extensions - they are contoured for a snug kit and turn the exhaust gasses 90 degrees down into the water. Ask your dealer for details. It would have been nice if Jeanneau had contacted owners - I found out by accident. I've noticed new Prestiges (42, 46 etc have had an exhaust re-design), so they definitedly got it wrong on the first 36's. I have Prestige 36 2004 and would like to get exhaust extensions but I asked from importer in Finland and they said they are not available from Jeanneau. Do you know any place in Europe where I could get these? Hi Artsi, Any luck with getting these extensions somewhere in Europe? I Need these Too...
