Self-adjusting topping lift
Jul 8, 2017 0:27:18 GMT
Post by Don Reaves on Jul 8, 2017 0:27:18 GMT
For a while now, I've been wanting to replace the 3-strand nylon topping lift on my SO35. It was always interfering with the telltales on the leech of my mainsail. To adjust it required a trip to the mast, which most times seemed like too much effort and other times seemed unnecessarily dangerous. I don't have a rigid vang, by the way.
I decided to use a light-weight high tech line (amsteel). Of course, because the line is very strong, it's diameter is so small that you need a tail that's more conventional in size. I decided to use a 5/16th inch (8 mm) polyester double braid. Splicing the two together wasn't hard. So I ended up with a two part topping lift, about 50 feet of 7/64 inch amsteel and 40 feet of 5/16 double braid.
I used the old topping lift to pull the new one into position. No problem. However, I discovered something that I hadn't anticipated when I started the project. The amsteel part of the topping lift is very much lighter than the polyester part. As a result, the working end wants to head to the top of the mast. In fact, it takes a pound or two of pull to keep it down.
Needless to say, it got away from me when I first tried to attach the shackle to the end of the boom. A trip up the mast solved that. The effort convinced me that I needed to be more careful. In fact I was worried that maybe I didn't want a piece of equipment that was inclined to make itself useless.
But the fact that the part in the mast is heavier makes my new topping lift self-adjusting. When the boom rises, it automatically takes up the slack better than I ever could by adjusting it manually. It's always away from the sail, so it doesn't interfere with the telltales. And being thinner, it has less wind resistance, another plus.
I hope I don't regret making the change. I've kept the old topping lift if I ever change my mind.
