Post by icantbuccaneer on Nov 14, 2016 10:59:47 GMT
Hi folks I hope someone can advise. there is a white block on the top of the sliding door that has dropped out as the securing screw had worked loose. Tholds the door securing bolt, ie keeps the door open. it looks like the only way to get access to fix back in place is to remove the door off the frame. I can't see any easy way of doing this, can anyone enlighten me thanks
Post by dj on Aug 11, 2020 12:36:32 GMT
Hi, Did you ever get any responses or manage to fix this problem with the bold that holds open the sliding door. I have the same problem and an struggling to get any information on how to fix this. I have even approached Jeanneau for details of the fitting but to no avail.
Thanks
