Post by erkan on Feb 6, 2016 23:14:02 GMT
Alex, I ordered the bearing according to Sailblue's pictures (1 3/4") and I belive this was the small one. It did not just slip into the bracket, I had to use the tool to insert it. I did not feel okey when applying force, but the shaft is rotating by hand. As I did not take out the shaft, it was not possible to clean the bracket hole. This maybe the reason for the thigth installation.
Post by alex1949 on Feb 7, 2016 22:06:59 GMT
OK, I see no problem but only future hard work getting it out again. But for this we have a cure by cutting the old CB inside. I only tried to convince that Jeanneau used both sizes and one should find the exact size of his CB bracket.
