following is the list what I currently have on my 1990 34 feet boat...
I definitely prefer Garmin then Raymarine - maps a lot better + easy to source...
I love the Garmin GDL 30 etc. weather layer - unfortunately available only for US ( north America) - in Europe using mobilke internet but discontinued
if you thinking about AIS go directly for AIS B transponder no point doing like me - VHF + AIS, Transponder and later connect to chartplotter...
Generic:Add-ins
- Fully batten Tri-Radial carbon/kevlar reinforced sails
- Spinnaker & Spinnaker/Whisker pole and all rigging
- Rock-solid horizontal windlass, Kobra 2 - 14kg anchor with 60m chain and 40m wrap ( 2015), remote in the cockpit + markers every 10
meters
- Second (kedge) danforth anchor 7kg and 60m wraps ( 2014 )
- Bow thruster MaxPower ( 2014 )
- Bedding/Sheets etc. special to fit exactly ( 2015 )
- Folding propeller - 17x13 - great while sailing(no resistance) and doing near 8kt on engine ( 2015 )
- Second reserved folding propeller 15x11 ( fully serviced/refurbished 2015)
- Fender 6 and one ball + fender socks
- Inflatable life jackets - 4 standard adult manual, 1 extra large auto adult, 1 child life jacket auto - all with crotch straps ( 2014 )
- Harness x 5
- Jack/safety lines bow to stern ( 2014 )
- 2 x 10L petrol cans for the outboard
- 1 x 20L diesel can for emergency for the engine
- Tools - about £5K+ in total including electric drills, saws etc. - all that you can imagine and you may need for servicing the boat from top quality! ( 2014 - 2015)
- Spares for all pipe related jobs - hose hot 30m roll, cold - 30m roll, all type of taps, valves and jubilee clips, extensions, fittings, strainers etc. ( 2014-2015 )
- Spares for all electric related jobs - clamps, cables of any type :220v; 12v; 10amp; 15amp, bulbs, connectors, fuses, adapters, measuring tools, boxes etc. ( 2014-2015)
- Emergency gel coat and fiberglass repair kit, marine sikaflex etc. ( 2014 )
- Spares for all engine related jobs, impellers, cables, fuses, pipes, oil, filters etc. ( 2014 - 2015)
- Weather station with temp in/out, atm. pressure, moisture meter, sun rise/set etc. ( 2015 )
- Top of the line professional fishing rod with all bites and tools and holder at the cockpit ( 2015 )
- Set of courtesy and hi-quality ensign with wooden pole ( 2014 )
- All paper charts for the mediterranean and pilot books for All med Spain , France, Balearics and Corsica - all up-to-date ( 2014 - 2015)
- 12v hi-power vacuum machine with 5m extension cable ( 2014 )
- Rechargeable light for use in the cockpit in the evenings ( 2014 )
- Diving LED Li-ion rechargeable torch 2000lm ( 2015 )
- Flat LED torch ( 2013 )
- Binoculars x 2 ( 1 x 2015 )
- Monocular ( 2015 )
- Hand compass ( 2013 )
- 4x winch handles
- All kitchen stuff extremely well kept original Jeanneau
- Emergency tiller ( 2015 )
Extra/Comfort Add-ins:
- All saloon cushions from cream eco-leather water resistant ( 2014 )
- Cream eco-leather water resistant with special extreme durable plastic base cockpit cushions ( 2014 )
- Watermaker/Desalinator 12v Katadyn 80E (12L per hour) ( 2014 )
- Watermaker electronic flow meter with LED display ( 2015 )
- Carbon water filter ( 2015 )
- UV - Water filter ( 2015 )
- Air Conditioner ( climatronic) - hot & cold - 8000BTU ( 2015 )
- 26" Full HD LED 12v smart TV/DVD/BlueRay with external 1TB HDD and Banten antenna ( 2014 )
- MyFi with extended antenna ( - wifi Internet on board ) ( 2014 )
- Sea water temperature meter with LCD display ( 2015 )
- Fridge thermostat with NTC temperature sensor - you will not have frozen food and you will still have ice for your whisky +
30% less consumption from your fridge ( 2015 )
- Bimini
- Large Sprayhood ( 2015 )
- Passarelle
- Plastimo ultra light dingy 2.4M with slatted floor + inflatable floor on top + 2.3hp very quite and powerful 2T Yamaha outboard - starts from half turn! and dinghy cover . ( 2014 )
- Davits with rollers for the dinghy - can be kept on the davits together with the outboard !
Electronics Add-ins:
- NASA battery monitor ( 2014 )
- Vectron battery guard with alarm ( 2014 )
- Garmin GPSMap 560 at the helm with advance sonar and full mediterraneen maps and attached to AIS ( 2014 )
- Top of the line EPRB with GPS ( 2014 )
- VHF ( Standard Horizon) with AIS and GPS and (RAM3)remote at the helm ( 2014 )
- AIS beacon/transponder battery powered(one charge 3 weeks) ( 2015 )
- Kenwood stereo with 5 CD changer
- 4 X USB hi-power (up to 4amps) charger points in every cabin and saloon for tablets phones etc. ( 2015 )
Electrics Add-ins:
- ALL LED lights - including navigation anchor, cabin, saloon etc. (2014)
- 240W Solar panels with MPPT controller ( 2014 )
- 600W Wind turbine with MPPT controller and carbon fiber pole + stop switch and automatic fuse/breaker ( 2015 )
- 5 x LFD75 Varta house batteries ( 2015 )
- 1 x 20ah Li -ion engine start battery ( 2015 )
- 6/12 amps charger ( switchable between 6amps and 12 amps)
- Trickle Charge 1.5amps ( 2015)
- Tubular heater 80W to be left ON during winter time. ( 2015 )
- Galvanic isolator ( 2015 )
- 50 amps engine alternator
Additional extras for nice life on board :
- Smart Inverter 3000W - 12v to 240v with remote, auto protection, breaker and fuse with automatic switch from shore power to inverter with hi-power relay ( 2015 )
- Bean-to-cup Jura Ena Micro Coffee machine (top of the line) - very electricity economical and doing the best espresso/coffee in the world! ( 2015 )
Does it still float?
