fau
Post by fau on Jul 24, 2015 23:17:14 GMT
My steering wheel is squeeking pretty badly. Today I removed the compass from the pedestal an lubricated the chain and all moving parts with mechanics oil. It didn't help at all. The sound seems to be coming from up near the wheel and not below at the cables. Should I remove the actual wheel using an allen wrench and lube there? Youtube indicated that the problem would be addressed beneath the compass but it didn't work. Thanks! 32' SO by the way.
Post by ianpowolny on Jul 25, 2015 7:59:11 GMT
We have a similar problem on our 45DS. Last year we had a noise and then the universal joint unscrewed from the steering D used in the auto pilot system. I haven't removed the compasses and wondered what you did to get the compasses off the binical? Ian
fau
Post by fau on Jul 25, 2015 10:08:45 GMT
Getting the compass off was easy. 4 screws, then lift the case, then compass. I thought that it would work after lubricating and it didn't, however.
Post by On y va on Jul 25, 2015 11:15:30 GMT
It could be the shaft bearings of the steering wheel. They are probably nylon (or similar) and at some stage they dry out. Start by spraying some WD40 in the steering wheel bearing (from the inside) and the end side too. And then a little on the outside of the steering wheel bearing. DonĀ“t need to take the wheel off for that really. Hope that helps.
jed
Country: Denmark
Post by jed on Aug 9, 2015 17:25:11 GMT
Hi I have a SO 36i from 2008 and the firdt years my stering wheel vas making noice, and no oil anywhere did help, then I loosen the stering cables just a bit and thath solve the problem with noice when using the Wheel.
Best regards Jens Erik
Deleted
Deleted Member
Post by Deleted on Aug 10, 2015 15:05:36 GMT
I had the same problem on our SO37 and so this vacation I lubricated the 2 wheels underneath the pedestal, so behind the 2 wooden boards in the aft cabins. This seems to help, the squeeky noise is gone.
