Post by ynotwash on Jun 6, 2015 16:12:31 GMT
Hi, we have a SunFast 37. The spring clip in the mast that prevents the mainsail runners coming out when we drop the sail is missing, but we are not sure what make the mast is and therefore what part we should order. Anyone know? Many thanks.
Post by MartyB on Jun 6, 2015 17:04:27 GMT
If you have parts that are rectangle, or a round slug, you can get three sizes at West marine in north america. Not sure what is available in the rest of the world. The smaller of the two plates is too small for my boat. the wider too wide, so I have to take a grinder to this one to make it fit. I keep an extra around so if one goes overboard.......not that this has ever happened........ Marty
Post by ynotwash on Jun 6, 2015 23:19:15 GMT
Thanks Marty, we are in the UK so hopefully we can get the same fitting here.
Deleted
Deleted Member
Post by Deleted on Jun 7, 2015 15:51:54 GMT
The brand is Z Spars. Check out zsparsuk.com. You need part 3522
Post by ynotwash on Jun 8, 2015 7:32:19 GMT
Well thanks Marien, it's hard to check on the website that the part is the right one, so I hope you're right because I have ordered it!
I'll let you know when we have fitted it.
Tony
