ian88
Post by ian88 on Jun 4, 2015 14:27:24 GMT
Can anyone help me to get my battery bank back to the original wiring. I took it apart in the dead of cold last winter and forgot to take a picture. There are two AGM batteries. A picture would be very helpful. Thanks
Post by so36idavid on Jun 5, 2015 1:09:18 GMT
Ian, I have a 36i and I am sad to say that a picture will not help . It's a rat's nest of red and black wires in there. Exactly what you need to do is dependent on what you did when taking it apart. And also what you or previous owners might have done in the past. You have to trace out each wire and understand what it does. I label each wire with a Brother label machine so that I only have to do it once. Once you understand what you have then compare that to the wiring diagram and wire it up appropriately. If you don't know how to read a wiring diagram then I suggest you hire a professional to do the wiring for you. There is significant potential for damage if you wire batteries up incorrectly. David
Post by shiook on Jun 5, 2015 18:25:34 GMT
I will take a photo or two for you tomorrow when I get to the boat. I've got two wet cell house and one motor - 3 batteries total. Also, the manual correctly depicts the wiring - do you have that schematic?
ian88
Post by ian88 on Jun 8, 2015 13:59:59 GMT
Thanks. I have the manual but it is not very clear.
Post by shiook on Jun 10, 2015 14:09:46 GMT
Please note there is a hand drawn sketch that I use to connect up with each season. I put color coded wire ties on each cable to coordinate with sketch. Good luck! Rob
