Post by DUET on Mar 29, 2015 21:01:15 GMT
2010 50 DS
Does anyone have any experience with a Speedseal impeller? I particularly like the quick release for inspection of the impeller because of its ridiculous location. Thanks.
Post by Zanshin on Mar 29, 2015 21:46:46 GMT
I used the Speedseal impellers on the 43DS and 49DS and loved it. The quick release made changes much easier than the normal screws and the system greatly increased replacement intervals.
Post by DUET on Mar 29, 2015 22:05:48 GMT
We're you able to install yourself or should it be done professionally. Thanks.
Post by Zanshin on Mar 29, 2015 23:00:12 GMT
The actual impeller housing is not changed, just the cover. Thus it is "a piece of cake" to exchange the original cover and O-ring with the new one. Getting the impeller seated correctly takes longer than the Speedseal change.
If they made a Speedseal for my current Jeanneau engine (VW 140-5) I'd switch in a heartbeat. I'd also like to change the impeller for my generator, as that seems to fail regularly.
Post by DUET on Mar 29, 2015 23:31:05 GMT
Very helpful and thanks! Maybe Jeanneau will use it on the Volvo engine for the subsequent 57's. Rather have the VW.
Post by MalcolmP on Mar 30, 2015 7:21:34 GMT
2010 50 DS Does anyone have any experience with a Speedseal impeller? I particularly like the quick release for inspection of the impeller because of its ridiculous location. Thanks. Yes good product, well amde and fool-proof. They now make a run-dry one which I have not used but looks worth fitting
Post by Tafika II on Mar 30, 2015 18:11:10 GMT
We had the original Speedseal kit on the Catalina 320 and added the LIFE version on our present boat. Make inspecting and changing the impeller a lot faster. Whatever your engine, Speedseal will know what your pump is and have the right unit for you. Cheap investment
