Post by J349er on Feb 22, 2015 0:53:35 GMT
The cockpit shower is the first item at risk of freezing so I'd like to install diverter valves inside my boat on both supply lines (hot and cold) so I can isolate the cockpit shower, drain its lines and keep sailing through the first few freezing weeks in fall/winter without needing to winterize the all fresh water system. So, two questions... - Are Jeanneau fresh water line inside the boat 1/2" diameter? (I have a 2015 SO 349) - Anyone with recommendation for a good diverter valve to use for this. I found this one from Bosworth that seems adequate. Thx.
