Post by MilesCAN439 on Jan 14, 2015 21:53:22 GMT
We are looking at entering a few offshore races with our Sun Odyssey 439 and one of the requirements is secondary steering if something should happen to the rudder while offshore. Yes we could use drogues but I'm not too comfortable with that so we are looking at an emergency rudder. Has anyone done this with the drop down transom and have photos? The boat is so good looking that I'm trying to figure out a way to do this without ruining the look of the stern. Any thoughts and/or suggestions would be greatly appreciated!
Post by sitara on Jan 15, 2015 6:33:08 GMT
I have set up a piece of plywood mounted on the spinnaker pole with a couple of U-shaped straps. The idea is to lash it to the pushpit and use it as something like a sweep oar.. I have not tried it yet and hope I never need it. The ply was from under one of the bunks that now has a few holes in it, so the only extra gear is the U-shaped straps and bolts.
Post by MilesCAN439 on Jan 15, 2015 17:47:12 GMT
We had it done this way on previous boats however we only fly assym's on this boat so we don't have a spinnaker pole. We are also thinking that if we are in the middle of the pacific that we would like to have something a little more robust. (I'm not sure if the jury rig spinnaker pole set-up would be allowed by the offshore regulations)
Post by hoppy on Jan 15, 2015 18:17:24 GMT
Post by jdl01 on Jan 16, 2015 1:04:23 GMT
The drop transom on the 9 series has nowhere near the strength to support an emergency rudder or sweep oar. Equally, the pushpits on these boats are far to weak to be any kind of anchor point for a sweep oar. Your best bet and easiest storage is a drogue system attached to your stern mooring cleats.
Post by dbostrom on Jan 22, 2015 19:01:31 GMT
Post by hoppy on Jan 22, 2015 20:13:47 GMT
The PDF is the same "test" as in the video I posted. So we can read the "book" and watch the "movie"
Post by On y va on Jan 23, 2015 8:20:21 GMT
I have a Hydrovane!!!
Post by jdl01 on Jan 24, 2015 0:25:45 GMT
After 25000 miles with a hydrovane, I can recommend it to no one.
Post by dbostrom on Jan 24, 2015 5:49:53 GMT
How is your hydrovane mounted, On y va?
