Post by popeye on Jan 5, 2015 22:28:25 GMT
Does anyone know how to remove the base unit. I have removed every screw visible, but the base unit falls to budge. Wishing to install a water heater in the large void. Any suggestions Mike
Post by MalcolmP on Jan 6, 2015 8:45:08 GMT
Jeanneau often use some glue as well as screws - on our boat I had to removes some of the saloon woodwork to gain access to the galley sink drain when changing the through hull valve and had same issue - removed all screws, but then had to prize a panel off to loosen the glue - it did delaminate slightly , but I was quite careful and it cannot be seen when re-installed.
If possible take some photos as the job progresses to help others with the same issue in future
good luck
