Post by J349er on Jan 3, 2015 18:57:44 GMT
349 doesn't have a sink splash guard... wondering if 379 splash guard would fit on 349. Could a 379 owner post a pic of their kitchen sink/counter? Attached is 349 kitchen sink/counter pic. Thanks.
Post by jdl01 on Jan 7, 2015 1:08:31 GMT
Hello 349, The 379 splashboard is 99 1/2m long. It is anchored by a pair of brackets which have a single point bolt which goes through the countertop. These are 23 1/2 cm from the outboard ends of the glass - centreline. The bolt holes are 2 1/2cm inboard of the inside counter molding. The forward edge of the plumbing fixture is 4 1/2cm inside the counter moulding. The glass rides 1cm above the height of the molding and is inboard enough that any splashes will drip on the counter; not down the back of the settee. The bolt holes are located to just miss the fridge box and the sliding drawer on the opposite side - hence accessible under the sink. Looking at your photo, it appears that your plumbing fixture is mounted much closer to the back counter molding than on the 379 - I suspect it will no fit. Do not despair - a custom bit of stainless designed to bolt through the vertical panel at the back of the settee should work and I would have a 1 cm thick piece of polycarbonate to act as the shield. It is a very useful feature and worth pursuing - good luck. Jim
Post by sitara on Jan 7, 2015 20:15:08 GMT
Hi j349er, Before adding a Jeanneau glass splash back check out some of the threads about exploding splash backs. I added an acrylic plastic splash back to my SO36i which was supplied without a splash back. See the thread jeanneau.proboards.com/thread/2272/exploding-galley-splash-back-so35 for details. Nearly three years down the track and it is still fine.
Post by richy on Jan 11, 2015 13:48:35 GMT
Perhaps the reason some boats don't have them is they are in just the right place for a grab handle, which clearly doesnt work out. There isn't one on my SF, are you sure you want one?
Post by J349er on Jan 11, 2015 22:35:31 GMT
Thanks for the responses especially JDL01 for taking dimensions. Still investigating....
