Post by lateron on Apr 4, 2014 11:03:38 GMT
Hi..........my bow roller has split. Apart from going through Clarke and Carter for a Jeanneau replacement, anyone know of an alternative and possible cheaper source. I believe it is made from delrin type material and measures 64mm wide. Help appreciated or shall I just go the Jeanneau spares route. Regards Ron
Post by MalcolmP on Apr 4, 2014 12:47:25 GMT
Hi Ron You should be able to get most engineers (or better still lathe hobbyists) to turn you one, using the broken one as a pattern Sailbleu should be able to advise on best type of plastic and you should be able to source in short lengths on ebay He made a couple of genoa rollers in this article: www.jeanneau-owners.com/hintsandtips/amiotgoiotgenoacars.htmlwhich are quite similar in principle Malcolm
Post by lateron on Apr 5, 2014 13:28:47 GMT
Thanks for that Malcolm, pretty impressive photos from Sailbleu. I know of a local lathe operator so may give it a try and get 2 made so I have a spare. Cheers ron
