speedbird1
Jeanneau Model: SO 45 DS
Yacht Name: Cloud 9
Home Port: Sant Carles de la Rapita
Country: Spain
Post by speedbird1 on Jan 23, 2014 13:12:28 GMT
Hi, from a newbie.
I have recently purchased a 2009 SO45DS. This boat was fitted with a Gori prop by the previous owner. I have no problems with this! He kindly left me the original 3 bladed prop as a spare. Unfortunately he did not leave the nut to hold this prop onto the shaft should it be needed. I have been dutifully carting this spare prop round with me (the boat is in Spain) for some time with no means of being able to use it.
I have been quoted a price of £150.00 for the nut and anode. This seems OTT for a "get me home" nut should I ever have to fit the spare prop for any reason. Does anyone know the size of nut (the material - steel or brass - doesn't matter as it will only be used in an emergency) to fit the shaft and/or where I can get my hands on one.
The engine is a Yanmar 75hp.
Many thanks
Post by On y va on Jan 23, 2014 14:22:59 GMT
Hello and welcome here! I am pretty new too! It seems very expensive. Is it a gold plated version? What is the diameter of the shaft? As that is the only important information needed really. Once I know this, I will have a look for you here on Mallorca (Spain). But I assume 35mm, that would be only like 40 euros for the nut and anode. The little "brake" plate, to secure the nut is 6 euros. Marco
Post by MalcolmP on Jan 23, 2014 14:43:59 GMT
The factory normally fit ELICHE RADICE props. You can get spare nuts and anodes etc in the UK from Sillette Sonic (who I am sure would post. You will need at least the shaft diameter - there will also be a spec stamped on the boss somewhere Useful datasheet for these props at: www.sillette.co.uk/price_pdf_files/eliche_radice_propellers.pdf
speedbird1
Yacht Name: Cloud 9
Country: Spain
Post by speedbird1 on Jan 24, 2014 19:15:46 GMT
Thanks guys. You've given me hope !!
