moodybod
Sun Odyssey 45 Performance WILD DREAM
Post by moodybod on Oct 1, 2013 8:25:13 GMT
Anyone know how the teak toe rail is attached? There is obviously a fastener under a plug through the deck but is it a screw or a through fixing?
Post by MalcolmP on Oct 1, 2013 8:45:32 GMT
I suspect that on the SO45 it will be screwed not through bolted as from about 2006 they used glue for the deck hull bond, you may be able to check visually where there is not an inner liner - maybe in anchor locker or aft lazarette?
moodybod
Post by moodybod on Oct 1, 2013 11:57:06 GMT
Thanks
