igloo
Post by igloo on Jun 17, 2013 13:00:40 GMT
have a leak from the top of the fuel tank in stb cabin on igloo - 36i - seems to be coming out of the outlet / inlet connections to the tank and appears to have been previously sealed with sikaflex - any suggestions as to what would be the best sealant / solution to problem? tank is nearly full and can see fuel leaking when I 'pump' the tank pushing by hand . Thanks John
Post by j on Jun 17, 2013 14:59:57 GMT
Post by Trevor on Jun 17, 2013 22:15:50 GMT
I had exactly the same problem on an SO 42 DS. I cleaned the surfaces with acetone to make sure no fuel residue was on the mating surfaces and used a product called "Gasket Goo" that so far has worked ok.
igloo
Post by igloo on Jun 19, 2013 7:35:02 GMT
thanks for that - have just bought some gasket goo here in NZ - will be over to Igloo after this low passes over us and try it out! - will keep in touch - thanks for the advice - John
Post by heelingpower on Jun 20, 2013 7:46:07 GMT
We are in NZ as well, had a similar problem last year and completely redid everything at the same time installed fuel polishing. we are in auckland if you want to have a look. as far as leak around existing flange. Ulrich Aluminium have a special self tapper for use on plastic I went up to the largest size possble madea gasket from white epdm and then refittted problem. Also fitted fuel inspection hatch.regards
