Post by shootash on Apr 8, 2013 16:27:02 GMT
Does anyone know how to access the inside of the burners. Also the oven will not stay alight. Any ideas?
Post by Tafika II on Apr 8, 2013 17:02:29 GMT
I had a problem when we first bought the boat. They replaced the gas feed solenoid and no problem since. Will your top burners work OK?
Post by shootash on Apr 8, 2013 20:19:31 GMT
the small one on the left will not stay alight, also the back big burner(also on the left) is not behaving, yellow flames and it seems to make a hissing sound after a popping noise.
Post by Tafika II on Apr 8, 2013 21:30:53 GMT
Sounds like a propane gas blockage problem. Start with the tank and go forward using bottle air and a plastic tube to blow out each section of line. I don't know how to test if the solenoid is working or not, I just replaced it and all worked. Good luck!
Post by electricmonk on Apr 9, 2013 15:32:11 GMT
try here for some info service.eno-marine.fr/mod_flash/index.php?id=MzExMA==sounds like the thermocouple (flame out device) is faulty along with a blockage that's stopping air mixing with the gas. you have several faults on three burners, it needs servicing. if your not happy to dismantle and reassemble gas equipment then don't, get an engineer in.
znick
Post by znick on Apr 12, 2013 6:28:12 GMT
A very simple trick that worked with my Eno Le Bretagne. Remove the knob, and but a little bit of curled aluminium foil in the knob before putting it in place. Don't ask me why it works, I didn't believe it when I was told. However after having changed the flame-out device without success, I tried with the foil with success!
