percy
Post by percy on Mar 29, 2013 23:06:52 GMT
I have a Merry Fisher 8.05 here in New Zealand and water can get in via the side windows on both side when we are cruising.
It must be a factory issue as the problem is the same on both sides and the water gets in at exactly the same place. has any one else encountered this problem ?
Post by carolyn on Aug 30, 2013 15:15:24 GMT
We purchased a Merry Fisher 805 in May - approx. 5 years old. It leaks on the port side via the side window when we are going through lots of spray / choppy water.
Did you find out where the water was coming in on yours? Did you get it fixed under warranty?
Carolyn
