Post by Seagem on Oct 29, 2012 13:19:03 GMT
I have just insulated my 60mm dia webasto hot air ducting and increased the heat output at the outlet by over 20%. I used some 80mm dia aluminum ducting that was already insulated with 25mm of insulation and threaded it over the webasto ducting. It only cost £27 for a 10m length, much cheaper that the Webasto insulation that costs approx £13 per 750mm length. OK so its not waterproof like the Webasto stuff but if it ever gets a soaking it will be the least of my problems!
Post by pbunning on Nov 21, 2012 10:15:51 GMT
We chose to have Webasto unit fitted by the dealer on our new SO33i rather than be factory fitted, because we wanted insulated ducts fitted.
It also turned out to be cheaper.
Post by sailbleu on Nov 22, 2012 5:08:53 GMT
I have just insulated my 60mm dia webasto hot air ducting and increased the heat output at the outlet by over 20%. I used some 80mm dia aluminum ducting that was already insulated with 25mm of insulation and threaded it over the webasto ducting. It only cost £27 for a 10m length, much cheaper that the Webasto insulation that costs approx £13 per 750mm length. OK so its not waterproof like the Webasto stuff but if it ever gets a soaking it will be the least of my problems! Could you supply us a webstore link or specific info on that Seagem ? Thanks Regards
Post by Seagem on Nov 23, 2012 9:05:33 GMT
I bought it on e bay from a company called Green Ventilation Supplies, which happened to be based near where I live in Sheffield UK. There are several suppliers on e bay if you search "insulated ducting"
Post by Zanshin on Nov 23, 2012 10:16:43 GMT
Aye'up, Seagem. I lived in Sheffield as well (within a stone's throw of the "Fat Cat" brewery). Not much sailing to do there, though...
Post by Seagem on Nov 23, 2012 11:55:22 GMT
Eyup Zanshin, I know the 'Fat Cat' very well, its still there! Yes you are right, not much sailing apart from dinghy sailing, which is where I got started at Rother Valley Country Park many, many years ago.
Post by sureyyagoksu on Dec 13, 2013 13:33:06 GMT
Hi everybody ,
I have a SO40 2002 and want to fit a air heating system either Webasto 5KW or Eberspcher. I will be gald if some one gives me info about the installation of Webasto. Which place is the best for locating Webasto device ? Where will I pipe ducting ? Please send me info if there is a SO40 owner who installed Webasto.
Post by Seagem on Dec 13, 2013 17:41:41 GMT
Post by sureyyagoksu on Dec 14, 2013 18:17:24 GMT
Thank you And. I checke but I am lloking for something official factory Install diagram for a Webasto 5000 heater on a SO40. I couldn't find any info about installing webasto on SO40. That's why I asked if there is someone who has SO40 with Webasto.
Post by dnickj on Jan 8, 2014 10:55:59 GMT
Hi
I have a SO40 with the webasto 5000 fitted - the heater is in the port cockpit locker with supply air being drawn from a transom mounted vent the exhaust is in he port side hull - i have to remove the heater to change the glo plug and will take a few pictures of the install
Post by sureyyagoksu on Jan 8, 2014 19:24:50 GMT
I love my SO40
HI Dnickj ;
I will appreciate i f you could take and send some pictures of air inlet, exhaust and heating points together with where you located the Webasto unit. Thank you in advance.
Sureyya
