Post by rodgerg on Aug 15, 2012 12:15:31 GMT
Hello folks last weekend I pushed the boat quite hard to get back home when we heard our daughter had a complication in childbirth. ( all ok now that way). Yesterday quite far back under the engine I found a sticky blood red deposit which had a sweet taste. My anti freeze is green so its not that. So I assumed transmission fluid! I took off the dip stick and found the level slightly higher than the ring mark near the bottom of the dipstick. I normally cruise under engine about five knots at 2500 revs. At times I was running at 3500 revs, however the engine sounded fine, and there was some still in reserve. Using a mirror I could not see anything obvious under the engine. Should I be worried or is it down to excess gearbox fluid?
Thanks Rodger
Post by Seagem on Aug 15, 2012 21:44:18 GMT
The small tube of grease in the Jeanneau spares kit that came with my boat is a red colour. Could it be some grease that has leaked out of the stern gland or a bearing, perhaps because the engine was running at higher than normal temperature? I haven't tasted (and don't intend to!) to confirm if it is sweet or not lol! I wouldn't worry too much at this stage, just monitor it.
Post by rodgerg on Aug 16, 2012 7:11:36 GMT
I know what you mean, I lubricated and burped the stern gland when i put her back into the water in February, however this is too far forward. I am pretty sure its from the gearbox but cannot understand how it could have got there. Rodger
Post by tedp on Aug 16, 2012 16:21:01 GMT
I wouldn't worry too much about running the engine at high revs. A mechanic who does the maintenance on mine says it's not a bad idea to occasionally open it up for an hour or so. I find the engine and transmission are much smoother afterwards, like in a car you drive a long distance at high speed. I don't know about the red stuff but like Seagem says I'd just monitor it.
Glad all is well with your daughter - can we congratulate you?
Post by rodgerg on Aug 16, 2012 18:30:49 GMT
My friend who has been sailing for years and is an engineer always nudges my throttle back a bit when he is on board, its a bit of a joke between us now. I agree I think it gives it a good clear out. Yes I am a Grandpa (second time around) to Fraser Craig Lindsay, a good Scots name thats for sure. I am heading off this weekend so will keep an eye on things Thanks
Post by tedp on Aug 17, 2012 11:10:26 GMT
A good Scots name indeed - congratulations! Good luck this weekend, if the weather out there is as good as ours you should have a good time.
Post by dolphinchaser on Aug 21, 2012 2:31:20 GMT
Rodger, my guess would be transmission fluid. Probably was a bit overfull and the high rpms and higher (possibly) heat may have caused it to "burp". I wouldn't worry about it unless it re-occurs.
