Post by dtamburin on Jul 29, 2012 1:39:26 GMT
On the steering pedestal there is an adjuster with 3 prongs sticking out of it behind the wheel. What does it do?
Thank you David
Post by sitara on Jul 29, 2012 6:31:59 GMT
It is a wheel lock. Turning in one direction will tighten and lock the wheel. Very useful when the boat is moored or in a pen as it prevents the wheel from working all the time.
Post by dtamburin on Jul 30, 2012 16:57:45 GMT
Thanks, apparently it does not work. Tried it tightened both ways, does nothing.
David
Post by sitara on Jul 30, 2012 22:42:08 GMT
It is a friction lock and on my old boat the friction surface was quite small, and it did not really lock the wheel up tight. My unit was fixed to the pedestal and tightened against the wheel - it may be possible to replace the friction pad if it is worn away leaving metal on metal.
