johnnyboy
Post by johnnyboy on Apr 11, 2012 1:29:00 GMT
On my 2010 42 so ds, there is a bilge area that i can't figure out how to access. It starts under the aft head shower floor, runs under the motor and under the galley sink area. It opens into a bilge area under the salon table through a small opening under the galley cabinets. a strong smell has developed under this area. I am trying to figure out I can access it so that it can be properly cleaned. any ideas out there?
Post by sailor666 on Apr 21, 2012 7:31:08 GMT
Try accessing from within the port and starboard engine mount mouldings. There are access holes and panels for this purpose. A little digital camera with flash is useful for inspection - be careful not to drop it though...
johnnyboy
Post by johnnyboy on Apr 26, 2012 0:43:24 GMT
i assume the engine mount mouldings are in the engine compartment?
Thanks for this info.
Post by sailor666 on Apr 27, 2012 8:15:53 GMT
johnnyboy
Post by johnnyboy on Apr 28, 2012 0:53:52 GMT
VERY helpful, thank you. never know these were there. still leaning the boat.
i did find the source of the smell. the aft holding tank thru hull valve has a small leak that goes into the bilge. discovered it last weekend while getting the boat ready to go back in the water from winter storage. I had to delay the launch while it gets fixed.
I'll also check the exhaust hose connection that you had trouble with.
Post by Spritz on Feb 18, 2014 14:08:10 GMT
Dear ALL, unfortunately the pictures are no more available , could you please help me? I have the same problem an they told me the only solution is to cut the floor of the bathroom and I want to avoid it......
please help! Thank you
johnnyboy
Post by johnnyboy on Jul 13, 2014 2:09:38 GMT
aside from the the access holes under the motor mounts, i could not find any other access ports for the area under the galley and sink. i ended up mixing a solution of cleaner and disinfectant and dumped it into the bilge from the access hatch next to the rear head. i then used a long handled bottle brush and tired to scrub the areas i could reach.
it eventually did the trick of removing the smell
Post by Spritz on Jul 13, 2014 22:04:28 GMT
Thank you!!
i need your help in the propeller topic, can you help me since we should have same boat?
