Post by jonhnybig on Mar 4, 2012 19:47:56 GMT
I have just taken delivery of 1 2011 July Merry Fisher 805, very pleased with her, apart from snagging problems, filled up with fresh water yesterday, bled system off, water had s strange taste, so we ran it of, filled up again, no water will come through taps now !any ideas
Post by ianqv on Mar 4, 2012 19:58:12 GMT
Hi,
Possibly air trapped in the accumulator. Should be located very close to your pump.
Ian
Post by Don Reaves on Mar 5, 2012 10:49:18 GMT
Check the filters on the taps. They can get clogged easily and will nearly stop the flow of water.
Post by Zanshin on Mar 5, 2012 12:36:01 GMT
Is your water pressure pump running when you do this or not? Does any water drip from the taps?
