Post by Tafika II on Feb 28, 2012 17:27:56 GMT
I am installing a oil changer system. Does anyone know what the thread sizes are for these two plugs as they are not listed on Yanmar's site or manual. Model year is 2007 Serial #E06649?
Post by Mistroma on Mar 5, 2012 22:37:07 GMT
I doubt you'll get an answer to this unless you are very lucky.
I've just ploughed through my Service Manual, Operation Manual, Technical Notes and Technical Outline documents for this engine.
Probably around 600 pages in total and all I managed to find is that it should be tightened to 48.9-58.9 N·m (36.1-43.4 lb-ft).
No mention of that specific bolt. I found details of general bolts used and closest match for torque was M10x1.5 44-54 (4.5-5.5).
M8 & M12 bolts lised had much lower or much higher torque.
So based purely on the torque, I'd guess it would be M10x1.5.
Sorry that I can't give a definitive answer.
Post by Tafika II on Mar 6, 2012 1:38:40 GMT
Hi Mistroma! Thanks for the reply. You found what I did & I think you for going thru this again. I did get a reply from one service dealer for Yanmar that the thread was a 14mm x 2.0. What I decided to do was drain both the oil & transmission fluids, remove the plugs and taken them to a "store" to get the same size thread fittings. Once I get the sizes, I will post them for others who may want to install an il changer. Thanks again! Brent
