Post by Amun Ra on Feb 19, 2012 17:20:43 GMT
Hello, I wonder whether anyone might know what this panel is for. it was in my 43DS when I bought it, but I have no idea what use it may serve? Is it a Jeanneau extra that was fitted on build? Best wishes Julian
Post by Zanshin on Feb 19, 2012 18:58:04 GMT
Amun Ra,
You picture, at 1Mb, is somewhat big; I've got slow WiFi here on the boat and gave up on trying to download it. The thumbnail looks like it is the output from a PC (I see VGA and COM1). What year 43DS is this on?
Post by Amun Ra on Feb 19, 2012 20:28:46 GMT
Zanshin,
My apologies, I will upload a much smaller res pic.
It is on a 2005 43DS, and yes, it does look like a PC output.
Best wishes
Julian
Post by Amun Ra on Feb 19, 2012 20:30:40 GMT
Zanshin - low res pic, I hope!
Post by Zanshin on Feb 19, 2012 23:04:28 GMT
Much better - it really does look like the output from a PC - COM serial port, USB port, VGA monitor output and a headphone jack all next to the typical 12V plug. My guess is that there is a PC somewhere behind your panels, or at least the wiring for installing one. It will be worth your time to trace the wiring in the hopes of finding a PC that you didn't know you had; or perhaps just plugging in a USB disk to see if it gets powered up and then tracing the wiring.
Post by Tafika II on Feb 20, 2012 1:22:09 GMT
If your boat has a TV, it's the connections from a laptop, MP3 player to the TV + a DC charger
Post by Zanshin on Feb 20, 2012 1:57:08 GMT
Tafika - I had to chuckle at myself when I read your post; you are most certainly closer to the mark than I and the only excuse I have is that I haven't owned a TV set in years but do realize that they are closer to computer/computer monitors than ever before.
Post by rxc on Feb 20, 2012 12:44:35 GMT
That is quite an interesting panel, and I, for one would like to know who made it, and if it (or something like it) is still for sale.
Where is it located on the boat?
Post by Tafika II on Feb 20, 2012 18:44:06 GMT
Hi Zanchin! You're right, I use my connections for computer monitor from my laptop used as a second station on my Raymarine setup via RGA-45 connector to my TV/monitor. It was made up from a standard wall box and various plug in components. I don't have a picture, but can send on later if anyone is interested.
Post by Amun Ra on Feb 21, 2012 8:19:45 GMT
Thank you everyone. Yes, I do have a TV installed on the boat, so perhaps that is what it is intended for. I have been trying to establish what happens when I plug various things into the panel sockets, but without much success so far. I had hoped I might have had a link to the Raymarine set-up on the boat, but it appears not.
The panel is located immediately adjacent to the bookshelf, on the front facing end of the switch panels.
I think I might have to unscrew it to check behind to see what wiring leads away from it.
Best wishes, and thank you
Julian
Post by Zanshin on Feb 21, 2012 12:04:05 GMT
That is quite an interesting panel, and I, for one would like to know who made it, and if it (or something like it) is still for sale. Where is it located on the boat? It looks like the typical layout and design of the Scheiber panels that Jeanneau uses. www.scheiber.fr
Post by rxc on Feb 22, 2012 21:58:00 GMT
Zanshin,
Do you have any links to a schieber web site that actually contains some content? I have been trying that URL for about 6 months, and it seems like the site is continually under construction, with lots of broken links and very little info about marine parts. And I am actually IN France, so one would think that it would work here.
Post by Zanshin on Feb 23, 2012 17:16:57 GMT
Now that you mention it, I do recall having had the same problem a year or more ago when I was looking for another panel. I think I found some French distributor who had real content online but cannot recall the name.
Post by Amun Ra on May 9, 2012 22:00:20 GMT
Excuse my resurrecting this thread, but I have identified the manufacturer and now have a link to their website for anyone interested. It is a DeltaNautic item: www.deltanautic.nl/Unfortunately I am no further forward in trying to make anything connect through it! Best wishes Julian
