Post by themontser on Apr 26, 2024 13:07:32 GMT
I need to replace the evaporator cold plate, which means re running the fridge lines behind the icebox. I am using a pull string to get them through, but they get caught on something behind the fridge every time. I can’t see or reach it, and I can’t find any way to access back there. Any tips?
Boat is a 2019 Sun Odyssey 349.
Post by moonshadow on Apr 26, 2024 18:05:46 GMT
I use a cheap endoscope camera that displays on a smart phone when I need to run cables etc. Sometimes I need to tape it to what I am pulling with. It can really help see what the obstructions are.
Post by loredo on Apr 29, 2024 8:13:23 GMT
This might not apply to your boat, I'll give it a try anyhow. The four different Jeanneaus I've worked on the fridges were all build +/- the same way. You need to remove the oven to get access to the panel behind it. That panel can be taken out and then allows a bit better access to behind the fridge(s). How exactly your kitchen is build I don't know, yet the proceeding should be more or less in that direction. Hope this helps.
