Post by bitsailor on Apr 6, 2024 18:17:25 GMT
Installing a new water sensor on the primary fuel filter. The connector is different to the previous sensor (looks like yanmar updated it). I need to buy the corresponding connector to attach to the sensor line on the engine. Can anyone identify what these connectors are?
Post by Trevor on Apr 7, 2024 20:59:59 GMT
Hello bitsailor,
They are 6.3mm spade connectors, one male and one female, each in a one way plastic housing. You could simply use normal uninsulated 6.3mm spade connectors and plug them into those connectors or you could purchase the housings to suit. They look very standard and with those photos should be able to buy them locally at an automotive shop or on ebay.
Kind regards,
Post by bitsailor on Apr 9, 2024 0:22:15 GMT
Perfect, thanks Trevor.
