Post by mickmeck on Mar 21, 2024 15:48:39 GMT
Has anyone removed the propane locker to get underneath? If so, what was your method? I am thinking of installing an arch and need to get underneath to anchor.
Post by rxc on Mar 21, 2024 17:32:44 GMT
Yes, I had the propane locker opened up so that Kato Marine could install my arch, 17 years ago. The locker on the other side will have to be opened up, too, and the tube removed for the work. I had the liferaft locker removed at the same time, for the genset installation. Removal of the port side tub allows good access to the steering gear for repair and maintenance. My propane locker was resealed shut, but the other one had remained removable.
I will look for eome photos.
Post by andreshs1 on Mar 27, 2024 6:22:15 GMT
Hi Mick
Not sure if this is the same thread we answered in FB, but just in case.
Removing the locker is a pain, as it is glued and there is very little room to maneuver, in addition, there is a drain tube at the bottom of it that you need to detach before pulling the locker fully out.
I will be on the boat over the weekend, I can take some photos
Post by mickmeck on Mar 27, 2024 13:36:21 GMT
Yes it is. Sorry for the duplication. If you can post pictures that would be great! Thanks in advance.
Post by andreshs1 on Apr 2, 2024 2:22:04 GMT
Hi Mick
Apologies... I missed the reply
I will go to the boat tomorrow or Thurs, I will send the photos then
cheers
Post by andreshs1 on Apr 4, 2024 15:11:46 GMT
Hi there see attached Regards Andres
Post by mickmeck on Apr 4, 2024 15:58:57 GMT
Thanks
