Fuel Polisher Install
Mar 11, 2024 19:45:11 GMT
Post by ianqv on Mar 11, 2024 19:45:11 GMT
Dear All,
With all the rubbish fuel being issued by nearly every marina going, I thought it would be prudent to add add some extra filtration. So the system I fitted just circulates the filtered diesel in and out of the fuel tank. It does not feed the engine in any way, it purely filters / polishes the fuel.
I'm a big fan of the Delphi (CAV) filter. Not only are they good and reliable, they are cheap and available just about everywhere!
So most of the parts were purchased from good old Ebay! The fuel pick up and return pipes are from a Defender! The Double Delphi filter will filter down to 7 < 9 microns.
Next was the installation. On my S/O 37 there was only one realistic option, under the starboard berth.
Then it was choosing a suitable fuel out / fuel in location on the tank. I had previously fitted inspection hatches on the tank, so this made it easy work. The red bits of tape denotes where the pipes will be fitted
Pipes being dry fitted before being bolted in using nitrile proof gasket and some sealer. At this point I forgot to take another photo, but on the end of the metal pipe there is a flexible pipe thats goes to the lowest point (right into the corner) so that any water or sediment will hopefully be sucked up filtered out.
Pipes installed (sorry I only took a picture of one of them, but the other one looked just the same!)
To try and make the pump as quiet as possible, I mounted it using these rubber cotton reel dampers
Fuel pump mounted
Then some fuel taps were added so everything could be isolated for servicing
I then cut out two additinal inspection holes so I can easily check for leaks
Then it was on to some glorious wiring! A 30 amp relay was fitted along with a discreetly mounted on/off switch
The fuel pump is rated at approx 75 ltr per hour, anymore than that I'm not sure the water traps will be that efficient as the fuel could be passing through too quick.
The eagle eyed would have noticed that I have used glass water trap bowls. I appreciate this may not comply with some off-shore regs, but I prefer to see whats actually happening with my fuel (plus I don't intend to cross an Ocean any time soon).
Its been filtering away for a few hours quite happily now (with no leaks). You can hear the pump running in the background and at a later date I may research replacing the pump with a solid state pump, but for now I'm happy with it.
Happy Filtering!!
Ian
Fuel pump mounted
Happy Filtering!!
Ian
