Post by Elcano on Mar 11, 2024 16:23:17 GMT
Hi,
my neighbours in the boat yard have zinc anodes on their bow thruster propellers. My bow thruster is the original one from Jeanneau (SO 409, 2012) and I do not have zincs. Do you have zinc anodes on your thruster props.
Thank you for your help.
Post by moonshadow on Mar 11, 2024 18:08:38 GMT
If you have “Quick” now thruster there usually are rounded cone shaped zincs for that.
Post by Elcano on Mar 12, 2024 16:36:53 GMT
I just checked the kind of bow thruster I have. It is a Max-Power CT100.
Post by Elcano on Mar 12, 2024 16:53:22 GMT
Post by Elcano on Mar 13, 2024 14:27:22 GMT
One more thing. If you have a Max-Power bow thruster, make sure you take off the props once a year and apply some silicone grease on the shaft. Helps to prevent corrosion. It is also mentioned in the manual!.
