Serenade (Sean R)
Jeanneau Model: Sun Odyssey 469
Yacht Name: Serenade
Home Port: Bristol, RI
Post by Serenade (Sean R) on Feb 2, 2024 20:56:12 GMT
Hi all...on Serenade (hull #116), the swim platform motor was struggling...it was slow, and needed "help" coming up. Left unassisted, it would grind to a halt and "click". So it needed a new Actuator Ram. I called Jeanneau, and the factory replacement was $1700 (ouch!). I did some research, and found the following HD actuator online for $320 (delivered). www.progressiveautomations.com/products/pa-hd1-linear-actuator?variant=42453695135924 I ordered the 18", 12V, 450lb model: Model: PA-HD1-18-450-N-12VDC It is a direct replacement. Works better than the original (faster/stronger). Keep in mind if yours dies... Sean
Post by moonshadow on Feb 8, 2024 0:01:04 GMT
Thanks for this tip. Sooner or later I suspect mine will fail also.
