ajv
Jeanneau Model: Sun Odyssey 410
Yacht Name: Alchemia
Home Port: Ionian
Country: Greece
Post by ajv on Jan 28, 2024 16:40:38 GMT
Has anyone fitted an Ultra Anchor to a 410? What are your thoughts good and bad.
will the Ultra Anchor fit under the Glasfibre bowsprit?
any advice very welcome thank you.
Adrian
Post by Chris Meyer on Jan 29, 2024 14:00:28 GMT
Has anyone fitted an Ultra Anchor to a 410? What are your thoughts good and bad. will the Ultra Anchor fit under the Glasfibre bowsprit? any advice very welcome thank you. Adrian Not sure, but this is a very expensive anchor compared to others I just looked at. It looks nice, but it is just an anchor. Not sure if it performs better than others.
Post by MalcolmP on Jan 29, 2024 15:02:55 GMT
Has anyone fitted an Ultra Anchor to a 410? What are your thoughts good and bad. will the Ultra Anchor fit under the Glasfibre bowsprit? any advice very welcome thank you. Adrian Hi Adrian I can't offer advice on the fitting, but you could ask them to supply a template ( I know Rocna do) You can buy direct from the makers and they will give a free swivel with any Ultra Anchor. Details are here: www.jeanneau-owners.com/discounts.html
Scroll down to Equipment Anchors Good luck, do let the forum know how it works out. Malcolm
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Jan 29, 2024 16:04:06 GMT
Thank you, there are very many good reviews for the Ultra anchor.
there are many anchors but if this gives me peace of mind then happy to pay the extra. The Delta I have as fitted by factory has failed to “bite” after the usual anchoring process, so many times here in Greece where the extra depth is sometimes required. By the way I also have 80 meters of chain and try not to leave it onboard when anchoring. Most of the time it’s around 50 meters laid out.
Post by MalcolmP on Jan 29, 2024 18:50:36 GMT
Thank you, there are very many good reviews for the Ultra anchor. there are many anchors but if this gives me peace of mind then happy to pay the extra. The Delta I have as fitted by factory has failed to “bite” after the usual anchoring process, so many times here in Greece where the extra depth is sometimes required. By the way I also have 80 meters of chain and try not to leave it onboard when anchoring. Most of the time it’s around 50 meters laid out. Yes we also sail in Greece and used to have a Delta, but upgraded that to a Rocnor a few years ago, which is miles better. Would go for the Ultra if I could afford it. Malcolm
Post by mehmet on Jan 30, 2024 16:26:51 GMT
Has anyone fitted an Ultra Anchor to a 410? What are your thoughts good and bad. will the Ultra Anchor fit under the Glasfibre bowsprit? any advice very welcome thank you. Adrian Hi Adrian, i am using Ultra since 8 years and I am really happy with it. In my previous boat a Jeanneau53 I had Delta and Ultra is way better then delta.
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Feb 2, 2024 15:50:58 GMT
Thank you for the information Mehmat.
information update
i found that the UA21 will fit below the bowsprit and as I have a 10mm chain I will also use the UFS10-35 swivel.
Delivery to Greece.
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Feb 2, 2024 15:53:46 GMT
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Feb 2, 2024 15:54:39 GMT
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Feb 2, 2024 15:54:58 GMT
Thanks for the information Malcolm, maybe we will cross anchors one day! We are based in Lefcas marina.
