Post by bitsailor on Jan 26, 2024 22:25:58 GMT
Hi, Trying to hook up the AUX button on our Scheiber panel on our 419. I have identified the connector on the back of the panel and it appears to be a 'Mate N Lok' connector. We are in Western Canada and I cannot find anywhere that sells these connectors, apart from wholesale companies selling in bulk. Since I just want to put a new wire in to hook up the aux, all I need is the female pin to crimp onto a new wire. Anyone know where i can get these connectors, and if there are any generic brands that are compatible. Photos attached, the connector I need to hook up is circled in blue. Thx
Post by kenheppell on Jan 27, 2024 11:30:44 GMT
Mate n Lok for Molex connectors. If you are in Western Canada RP Electronics in Burnaby sells them.
Post by bitsailor on Feb 8, 2024 18:35:39 GMT
Mate n Lok for Molex connectors. If you are in Western Canada RP Electronics in Burnaby sells them. Hi Kenheppell. Just a quick thanks, managed to get the connector at RP electronics - not the exact same but was able to make it fit fine.
Post by ianr on Apr 12, 2024 10:32:08 GMT
Hi bitsailor,
I just spotted this thread . I am planning to do the same - did you determine the precise female pin terminal required. There appear to be several TE MATE N LOK Terminals, a universal, a .140 type and also "commercial". Thanks, Ian
Post by bitsailor on Apr 12, 2024 15:49:45 GMT
Hi Ian - this is what I ended up buying - note was cheaper to get a connector set, but I only ended up using one of the female connectors. They were not a 100% match I think they were just a slightly loose fit, so used a pair of pliers to make them a little tighter. Other than that no issues and its been working great. Looks like you are located in europe - not sure where you can get them there, but an electronics shop might be able to look up the same connectors as in the photo. Good luck
Post by cpetku on Apr 13, 2024 3:21:44 GMT
DIGIKEY (dotCOM) is your friend and ships worldwide (for a price)
