Post by moonshadow on Nov 25, 2023 12:37:18 GMT
Hello again. Have any of you figured out how to access the outside of the fridge and freezer to add insulation? A while ago I tried disassembling the cabinetry and gave up whe. It started turning into a bigger job than expected. I considered spray foam insulation but was concerned about future complications like pulling cables if ever needed. Anyone have success?
Serenade (Sean R)
Jeanneau Model: Sun Odyssey 469
Yacht Name: Serenade
Home Port: Bristol, RI
Post by Serenade (Sean R) on Feb 2, 2024 20:59:28 GMT
I'm about to replace the compressor for the freezer compartment. Also going to refinish the interior. While I'm in there, I'll look to see if there is any easy way to add insulation. The frig/freezer come as a unit from Vitifrigio, so it is kind of monolithic...not sure you can get access behind/along the sides easily.
Post by moonshadow on Feb 7, 2024 23:59:37 GMT
Thanks. Please do update as you work on yours. I haven’t gone back and explored the area covering the fridge and freezer yet. Just been lazy and busy with other projects.
