Post by olallaviking on Nov 24, 2023 19:56:21 GMT
I just purchased a 2019 Jeanneau NC 895 and discovered that it was leaking water in the master cabin right where the end of the curtain track is nearest to the bow of the boat. Upon further inspection with a micro cable camera it appears that rain water is leaking in and collecting in a trough running across the bow just above the mirror and when the boat moves from side to side water leaks out and down the window ledge and then to the floor. The leak is fairly bad but luckily no mold yet. The dealer is on the hook to fix it but who knows when that will be. Has anyone else had this issue? I suspect it may be coming from the sun deck area but as everyone knows water travels so who knows.
Post by ceki on Jan 15, 2024 7:06:18 GMT
Hi there, I had similar problem with 895 Marlin and it was due to cup holder drain pipe disconnection issue over the bow sunpad area. It's fixed immediately once we sikaflexed the drain hole of the cup holder.
