Valor323
Jeanneau Model: 41 DS
Yacht Name: Ciao Bella
Home Port: Glen Cove
Post by Valor323 on Sept 19, 2023 15:53:34 GMT
Hi Everyone, Looking to see if any of you store their outboards on the aft rails, and if so, which mount are you using? The twin top tube seems to be making a simple rail mount purchase complicated. Looks as if custom is the only approach. Can anyone with a functioning system please share what you are using? Many thanks in advance.
Michael
Post by whiteswan on Sept 19, 2023 19:30:04 GMT
Hi Micheal, l purchased a outboard bracket that fits on both rails from the Jeanneau dealer. Not cheap but is a orginal design bracket for the 41 & 44 DS.
garrettw
Jeanneau Model: 44DS
Post by garrettw on Sept 29, 2023 21:21:54 GMT
I made a custom bracket from a 8" wide teak board. I cut two identical ~16" lengths and used a 1/2" half round router bit to put a semicircular channel where the two topmost aft rails go. Then I bolted the two planks together, sandwiching the rail in the channels. It was maybe an hours worth of work and has been on my 44DS for 8 or so years now.
