Post by moskma on Sept 15, 2023 18:03:02 GMT
I need to bleed and fill the hydraulics on the above. Does anyone have any experience with the L&S unit and whether the fittings on the bleed and purge kits readily available here e.g. Outboard Specialty Tools Bubble Purge G2 Hydraulic Steering Bleed and Purge Kit -- will fit the L&S fittings? It seems the L&S unit is not uncommon to Jeanneau and Beneteau
Trying to come down the learning curve on this. Too bad its not a seastar unit . . . at least there is a good deal of info available for that product.
Thanks Mark
Post by allinev on Sept 17, 2023 7:19:21 GMT
I have the exact same question. Let's hope someone here can help us. The bleeder valves on the cylinder appear to be different from the ones on the Seastar, so most of the kits with quick connects on the tubes (like Bubble Purge G2 ) won't work. Since they're from France/Europe, I doubt I'll be able to find quick connects that fit the Lecomble & Schmitt bleeder valves?
Post by shaodx on Sept 20, 2023 4:04:25 GMT
Don't buy G2 as you can build it by yourself easily, just buy 1/4 hose and some fittings. The L&S uses same male fittings which Airbrush Quick Release uses.
