Post by sanjuan895 on Sept 4, 2023 6:25:54 GMT
My windless has stopped working — was trying to find the circuit breaker and I’m stumped on where it’s located. The manual is no help with “positioned between the relay and the batteries.” That doesn’t narrow it down much.
Anyone know where the breaker is located, or any other trouble shooting tips?
Thanks in advance.
Post by Trevor on Sept 4, 2023 8:20:41 GMT
Hello sanjuan895
What model vessel do you have? With that information perhaps a forum member can tell where that is on their boat.
amica
Jeanneau Model: Sunfast37
Post by amica on Sept 4, 2023 10:52:00 GMT
An inductive pen that detects 12v will help you find out if the break is upstream or downstream . I would start at the windless switch end as the switches particularly 9f they are foot switches are prone to corrosion . You can also test your windlass. By applying 12v direct to the terminals . The fuse assuming there is one ! Is probably a 100A resettable link . Mine is below the switch panel not immediately obvious but it depends if you have a battery located forward close to the winch or if it is wired with heavy cable from the main battery bank
mjbwa
Jeanneau Model: 895 Sport
Home Port: Edmonds, WA
Post by mjbwa on Sept 4, 2023 13:38:55 GMT
On the 895 Sport and I believe the weekender, the circuit breaker is located in the battery switch area.
ea
Jeanneau Model: NC 895
Home Port: MIDLAND, ON
Country: CANADA
Post by ea on Sept 4, 2023 23:50:12 GMT
if it is an 895(not sport), it is in the main battery switch box, as circled on the attached picture
Post by sanjuan895 on Sept 5, 2023 0:10:24 GMT
2017 895 Offshore. I must be blind because it looked right over it. It’s at the end of the galley with the rest of the power cut-offs:
Post by Don Reaves on Sept 5, 2023 1:01:55 GMT
You certainly aren't the only one to miss the windless switch. The one on my Sun Odyssey 35 is in the aft cabin (where it's quite dark) next to the main ground cutoff. It's black on a dark wood panel, so you won't see it unless you know where to look.
