Post by tomj on Jul 21, 2023 9:45:03 GMT
I have Sun Odyssey 32 Legande with Yarmar 19hp . Shaft Drive .
Date made : 2007
During sailing last Sunday the propeller came off .
Could you please let me know if you would know the best place to get a replacement 3 blade fixed manganese Bronze propeller for this boat.
If you know the Propeller specification that would be great.
Thanks
Post by sitara on Jul 21, 2023 22:26:40 GMT
What bad luck, at least this gives you the opportunity to replace the propeller with a folding or feathering propeller if you want. These props will give you more boat speed under sail and probably better pointing ability. Propeller suppliers will be able to determine the best propeller specifications for your boat. They will need some data such as water line length of the boat, displacement, maximum engine rpm and gearbox ratio. The factory fitted propeller on my boat was overpitched and would not allow the engine to rev out, so the factory fitted prop specifications should be used as a guide. Hope this helps, Rob
