For Sale. Jeanneau Sun Legende 41. Based in Sicily
Jun 3, 2023 12:32:41 GMT
Post by MalcolmP on Jun 3, 2023 12:32:41 GMT
For Sale - Cascade II - Jeanneau Sun Legende 41.
Based in Sicily
71,000 USD. (approx 66000 Euro) Please contact Bill, or Tyler directly on numbers below if you have questions.
Info:- CASCADE II -SUN LEGEND 41. Designer: Doug Peterson
Builder: Jeanneau
Year: 1989 VAT paid
Flag: Polish
Hull material: Kevlar/Glass fiber laminate with Polyester resin.
Motor: Perkins Diesel 50 hp. 5,800 hours (Never EVER failed to start on the first push of the button. Oil and filter changed every 250 hours. Rear main bearing seal changed 2019, new water pump and complete engine service 2023
LOA: 12.25 m.
Beam: 3.9 m
Draft: 2.2 m
Tankage
Fuel: 150 Liters
Water: 3 stainless steel tanks. 2-90 Liters: one 140 Liters
Accommodations: Three double cabins, with a brand new custom foam mattress in the port aft cabin with reading lamps at the head of every bunk. Small hanging locker in each cabin.
Head: Manual Jabsco toilet, Hand held shower with sump drain pump out.
Galley: Fully equipped galley with a 3 burner Dometic cooker (German) with oven and grill. Hot and cold pressure water. Hot water by 220 volt boiler and Perkins motor. 12 volt fridge with Danfoss compressor. New in 2016. It makes ice and freezes fish and meat.
Electrical Equipment:
4-Victron AGM batteries, 115 amp hours each. New 2022. 3 130 watt solar panels mounted on an arch that doubles as a davit for the tender. . Quick 40 amp AC battery charger. New 2018. Victron Bluetooth solar panel regulator. New 2019. 600 watt Laffette modified sign wave inverter. New approx. 2015. 100 watt 220 volt GFI system. 12 volt and 220v Electrical panels. AM/FM CD stereo player. All interior reading lights are solid brass bell shaped lights with LED bulbs. There are 6 permanently mounted fans plus one portable fan.
Navigation equipment:
Furuno GPS: Lowrance VHF: Simrad AIS, send and receive. NASA Marine weather receiver. Shipmate CP32 chart plotter. Raymarine Wind speed & direction, depth sounder & speedo: Raymarine 6000 autopilot. Linear drive. Masthead tricolor and anchor lights.
Deck: Lofrans Caymen windlass. 60 meters of 10 mm chain. Serviceable and strong but surface rust becoming annoying. Chain end for ended annually.
Anchors and Rodes: More than you will ever need...
20 kg Delta anchor. Fortress 27 with 1.5 meters of chain rigged on the pulpit for tandem anchoring. 60 m 18 mm nylon anchor rode. 40 m nylon anchor tape. 15 kg Fisherman anchor in deck chocks.
Rigging: 8 mm and 10 mm high quality German 1x19 standing steel rigging. Wire and swedges renewed 2010. Professionally inspected in 2017 and by owner annually.
Under water gear: 3 Bladed Max Prop feathering propeller. All sea valves renewed 2010 with high quality Italian silicon bronze valves. PYI dripless stuffing box.
Keel: Iron. Stripped bare and faired with International Paint Co. epoxy system with glass fiber coating. Work done by Trapani Boat Services 2014.
Sails/Deck gear: Cutter rigged. Selden head sail furler. New drum and upper swivel 2019. Harken staysail furler. New 2019. 90% working jib, new 2010. Staysail new 2019: Mainsail 3 reefs: All from cockpit. 130% genoa. Never used. Storm trisail. Never used. Lazy jacks and Lazy bag. Both headsails have sun protection leech and foot.
Winches: 2 Barbarossa #52 self-tailing cockpit winches. 2 Barbarossa # 42 self-tailing main sheet/halyard winches on cabin top in cockpit. 2 Barbarossa #40 staysail winches on cabin top
Solid, varnished, teak, cockpit table hinged to the pedestal guard when not in use. Fitted cockpit cushions.
Stamoid spray hood. New 2016, due for canvas renewal. New Bimini 2019 which attaches semi permanently by zipper to the back of the spray hood. Summer side curtains to block sun. Winter side curtains for full cockpit enclosure. Spray hood frame has hand grips on the aft and both port and starboard sides.
Safety Gear: 6 person Life raft in valise. Serviced by Eurovinil SPA. on regular basis. Next raft service is due February 2020. 406 mhz Emergency Beacon. Deck safety tapes and Horse shoe life ring.
Sailboat data link: sailboatdata.com/sailboat/sun-legende-41-jeanneau/
Contact:- Tyler Salvo, telephone + 1805 570 5062 Tahoe, California or Bill Salvo + 39 366 244 6750, Ragusa, Sicily
Based in Sicily
Builder: Jeanneau
Year: 1989 VAT paid
Flag: Polish
LOA: 12.25 m.
Beam: 3.9 m
Draft: 2.2 m
Tankage
Fuel: 150 Liters
