captainden
Jeanneau Model: Merry Fisher 795 S1
Post by captainden on May 30, 2023 8:27:43 GMT
Not sure if you came across with this. I noticed that that I can still turn the wheel slowly if that reached its end position both ways. I also have to steer continuously bit by bit right in order to drive straight. That should mean there is a leak in the system.
Steering oil level is OK, thus I was going to find our if there is a internal leak in the helm pump or the steering cylinder. But then I noticed that one of the hoses from helm pump to 3-piece joint under the floor in aft big hatch is sweating. It's a little oily all the way long.
Any advice on how to go forward? It is a common issue with LS system?
Thanks!
