murina
Jeanneau Model: Sun Odyssey 45
Yacht Name: Morava
Home Port: Kavala
Country: Greece
Post by murina on May 8, 2023 21:43:05 GMT
I wonder if there is a table available for propeller specs for each Jeanneau model: diameter, pitch, make, model, part number... In particular, I am looking for the right prop for Sun Odyssey 45 (production years 2004-2009), equipped with YANMAR 4JH4-TE, 75HP, with 35mm shaft. Standard, bronze 3-blade fixed. Thank you.
Post by sitara on May 8, 2023 21:53:46 GMT
The answer is probably no. Your best bet is to decide on a propeller and then talk to the manufacturer/reseller. They will need boat displacement, length at waterline, engine power, maximum rpm and gearbox ratio and will be able to calculate the optimum diameter and pitch for your boat. Alternatively you existing propeller may have its diameter and pitch stamped near the shaft assuming it is giving you correct performance. And welcome to the forum, you will get lots of help here.
murina
Yacht Name: Morava
Home Port: Kavala
Country: Greece
Post by murina on May 9, 2023 8:10:37 GMT
Thank you Sitara. The problem is that the prop is in the deep mud at the bottom of the harbour and cannot find it. I hoped someone from Jeanneau can access the original Bill of Material when the boat was assembled, it must include the prop manufacturer and part number. Even if no longer available, I could learn about the geometry. Does anyone know if such tech support exists?
I bought that boat recently and lost the prop on the maiden voyage, although a big one, almost 1000 miles form Malta to Kavala, Greece. It happened literally withing the last 50 meters of the trip when I engaged in reverse to approach the dock. A lot to learn about sourcing parts.
Post by MalcolmP on May 9, 2023 10:17:57 GMT
You could try an email to Jeanneau customer support at: service.client@jeanneau.fr They will respond to requests in either English or French Include your Hull HIN number and year of build. Please let the group know how you get on. Good luck. Malcolm
Post by fma on May 9, 2023 16:04:19 GMT
My SO45 (same engine spec as yours) but with a MaxProp uses 20 degree Right Hand
Post by xpresident on Feb 20, 2024 15:25:04 GMT
Does anybody can give me the dimensions of the propeller of Sun Odyssey 33, 1995 ? Or manufacturer's name?
