Post by Hanzel on Apr 13, 2023 11:25:50 GMT
Since the beginning we have problems with a wobbling table, so I decided to look for the reason and even better: the solution. After disassembling the pilar, I found small plastic caps which were slightly worn. By inserting stainless steel rings dia 5 mm at one side, problem solved. Pictures will follow. Hope this is helping others. Attachment Deleted Attachment Deleted
Post by chris200 on Apr 18, 2023 20:12:53 GMT
Are this flat washers or wire that is bent into a circle? Did you buy them or make them? Having the same issue so thanks for the help.
Post by Hanzel on Apr 18, 2023 21:17:06 GMT
Hi Chris, I used stainless steel flat washers for m5 bolts, thickness I think 1 mm only. When you have more wear on the noses, you can put more washers also at the others in the circle. For me, only 3 out of 6 were good.
Boatruptcy
Jeanneau Model: NC11
Yacht Name: Boatruptcy
Home Port: Annapolis MD
Country: US
Post by Boatruptcy on May 9, 2023 15:30:00 GMT
Hanze,
Thanks for the suggested fix. The table was driving me crazy! Your fix worked perfectly! Now on to the next project!
Chris G
