Post by mickmeck on Jan 30, 2023 13:59:46 GMT
In 2021 as I was fixing my compression post pad issue I took the time to tear apart the floor under the saloon table and install drawers. They have proven to be a very handy addition. I have attached a PDF with some pictures and description of my process. Hopefully this helps others who would like to tackle the job. 43DS Drawer Installation.pdf (622.7 KB)
Post by Chris Meyer on Jan 31, 2023 11:58:23 GMT
In 2021 as I was fixing my compression post pad issue I took the time to tear apart the floor under the saloon table and install drawers. They have proven to be a very handy addition. I have attached a PDF with some pictures and description of my process. Hopefully this helps others who would like to tackle the job. View AttachmentVery impressive work! Not sure I could tackle that and have it come out as good as your work. Chris
Post by Tafika II on Jan 31, 2023 18:28:08 GMT
On the 43DS is the table area raised or did you raise it? My SO42DS is flush with the rest of the floor.
Post by MalcolmP on Jan 31, 2023 19:38:59 GMT
Post by mickmeck on Jan 31, 2023 19:59:24 GMT
Post by mickmeck on Feb 1, 2023 2:54:21 GMT
The scariest part was tearing up the floor. once that was done it was just building boxes. Thanks for the compliment.
Post by mickmeck on Feb 1, 2023 2:57:16 GMT
Yes, I saw that and asked many times for more details. it was because of that post that I wanted to do this. My friend Rik started the removal of the floor and then we saw it wasn't scary so removed them.
Post by mickmeck on Feb 1, 2023 2:57:55 GMT
On the 43DS is the table area raised or did you raise it? My SO42DS is flush with the rest of the floor. The floor was already raised.
